Arc Text on BOTTOM of arc
Paul.Devitt
Paul.Devitt
Autocad 2019
I need to create some arc text for laser cutting and I cant figure out a solution to put it along the bottom of a circle or arc. I can create arc text for above an arc but not under a design in a lower arc so to speak. In the attached picture, "BACK ALLEY" was created with arc text, but "CRUISERS" had to be created as a straight line of text and I then had to rotate and move them as single letters, it is VERY time consuming, is there actually a way to get this done like the upper arc text or am i screwed?
Thanks.
natasha.l
Hello @Paul.Devitt
Please watch this video on how to use the ArcAligned by going back & selecting a different option will give the result you are looking for.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
