Arc GIS For Autocad Lisp file
Has anyone had any luck getting this cad toolbar add-on to load without issue.
I'm trying to get it to load on startup in my Civil3D and AutoCAD environment.
This is the lisp file that I found on the web relating to it
Lisp file called ArcGIStoolbarAUTOLOAD.lsp
(command "_ribbon")
(command "netload" "C:\\Program Files\\ArcGIS for AutoCAD 370\\ArcGISForAutoCAD")
Problem is I cant see it in my startup cad session so I used appload to load it.
I have created a tool button with the code below to load it but it doesn't work. I get :"error load failed" at the command line.
This is my button coding      ^C^C^P(load "S:/xx/xx/xx/xx/ArcGIStoolbarAUTOLOAD.lsp")
The x represents my network path.....this doesn't work though.
Any ideas where I am going wrong?
Alfred.NESWADBA
what happens when you start the command _NETLOAD manually and point to that file?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hi Mark,
I added the Autoload commands for ArcGIS 4AutoCAD 370 (those you described in your discussion) at the end of acad2020doc.lsp and it worked, but, it will disable all the object snaps I have set. This is a minor and fixable issue so, if you can find another position in the lisp where it does not interfere with your current settings pls let us now.
Good luck
Jonathan3891
Add the commands to the ACADDOC.lsp file.
You can also have ACADDOC set your osnaps using:
(command "OSMODE" "135")
Remember to replace "135" with your desired number.
Jonathan Norton
Blog | Linkedin
