I am currently using AutoCAD 2010. I'm placing some length dimensions on partial sections of a circle and the arc dimension comes straight out from the chosen points as a dimension of a flat line does. I would like it to look like an angular dimension without having to use a text override. Is there any way to change that to where the placed dimension lines follows the edges of the section instead of coming straight out?
