Applying Field to Multiple Objects
paulmcclafferty4
Message 1 of 11
paulmcclafferty4
I need to use the FIELD function to extract attributes from multiple objects at once.
The "roadnamela" is the attribute I need.
There are 4 roads in the attached drawing sample, however my aim is to name hundreds of roads using this method if I can complete this action at once.
Thanks in advance for the help.
Replies (10)
Message 2 of 11
imadHabash
to extract attributes in AutoCAD you can use DATAEXTRACTION command . >> Click <<
Imad Habash
Message 3 of 11
serkancavuslar
@paulmcclafferty4 @imadHabash
Attribute Block Multiple Select and mText 🙂
Serkan ÇAVUŞLAR
CplCAD İstanbul / Türkiye
	(defun c:attmt(/ aDoc aSp oSiz bSet aLst cLst tStr nTxt bCtr Tags TextInsert)
		(setq Tags nil)
		(setq TextInsert T)
		(defun GetBoundingCenter (vlaObj / blPt trPt cnPt)
			(vla-GetBoundingBox vlaObj 'minPt 'maxPt)
			(setq	blPt (vlax-safearray->list minPt)
					trPt (vlax-safearray->list maxPt)
					cnPt (vlax-3D-point (list (+ (car blPt) (/ (- (car trPt)(car blPt)) 2.0)) (+ (cadr blPt) (/ (- (cadr trPt)(cadr blPt))2.0)) 0.0))
		(if (not Size) (setq Size(getvar "TEXTSIZE")))
		(setq  oSiz Size
			   Size (getreal (strcat "\nText size <"(rtos Size)">: "))
		(if (null Size)(setq Size oSiz))
		(setq aDoc (vla-get-ActiveDocument(vlax-get-acad-object)))
		(if (= 1 (vla-get-ActiveSpace aDoc))
			(setq aSp (vla-get-ModelSpace aDoc))
			(setq aSp (vla-get-PaperSpace aDoc))
		(if (setq bSet (ssget '((0 . "INSERT"))))
			(progn
				(foreach b (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex bSet))))
					(setq	aLst '()
							tStr ""
					(if TextInsert
						(setq bCtr(GetBoundingCenter b))
						(setq bCtr(vla-get-InsertionPoint b))
					(if ;(and
							(= :vlax-true (vla-get-HasAttributes b))
						;	(safearray-value
						;		(setq atts (vlax-variant-value (vla-getattributes b)))
						;	(foreach tag (vlax-safearray->list atts)
						;		(= (vla-get-tagstring tag) "roadnamela")
						(progn
							(setq aLst (mapcar '(lambda (a)
								(if (= (vla-get-TagString a) "roadnamela")
									(list (vla-get-TagString a) (vla-get-TextString a))
									(list "" "")
								) (vlax-safearray->list (vlax-variant-value (vla-GetAttributes b)))))
							(foreach i (reverse aLst)
								(setq tStr (strcat tStr (if Tags (strcat (car i) ": ") "") (last i) "\\P"))
							(if (/= "" tStr)
								(progn
									(setq nTxt (vla-AddMText aSp bCtr (* Size 30.0) tStr))
									(vla-put-Height nTxt Size)
				(vla-EndUndoMark aDoc)
	 (princ)
Serkan ÇAVUŞLAR
CplCAD / Türkiye
Message 4 of 11
paulmcclafferty4
Thank you very much! you have saved me a LOT of time!
Message 5 of 11
I don't understand, is this a script I need to run?
Message 6 of 11
Michiel.Valcke
This is autolisp code, you save the code as a text file with the extension .lsp (you can also download it from @serkancavuslar 's post.)
You can add the code to your AutoCad with the command _APPLOAD
Once you have done so you can call the command from the command bar (in this case the command is ATTMT - you can always recognize it because it is prefaced with the code: " defun c: " )
Message 7 of 11
aponsBA4NG
hello!
I would like to know if it would be possible to do the same with the properties of hathces
I have tested the lsp with hatches and it does not recognize them as objects
thanks in advance for your time!
Message 8 of 11
joelTFPVU
Community Visitor
Community Visitor
I want to use this script to assign text showing the elevation location of each point. what would
I have to change in that script to make it work?
Message 9 of 11
joelTFPVU
Community Visitor
Community Visitor
For example, I can link a text displaying the field value of Position Z for each point. But If I have 238 elevation points I don't want to manually do each one. Can a similar script be ran for this.
Thanks!
Message 10 of 11
Michiel.Valcke
If you have an AutoCAD full version (not LT) then you should also have access to the AutoCAD MAP 3D toolset (you have to install it as a separate software, but it is included in the same license) you can add text labeling for such things directly with AutoCAD MAP 3D workflows, no need to use fields.
Message 11 of 11
joelTFPVU
Community Visitor
Community Visitor
Thanks, yeah I do have the full version. I just downloaded the AutoCad Map 3D.
I will play around with that,  see if I can figure it out.
