Apply Plot Style to Batch Plot pdf
Message 1 of 25
I am trying to batch plot to a pdf with the monochrome plot style.
Unfortunately the best I can get is that the monochrome plot style is applied to the drawing that I have opened but not to all of the other drawings that I have added to the batch plot.
Here I have opened the first drawing of the drawings that I wish to batch plot
Next,  I have modified the default page setup for the drawing to the monochrome plot style
Next I have selected batch plot
Next I have added the required drawings to the batch plot
Next I have applied the default page setup of the original drawing that I opened to all of the other drawings in the batch plot.
Next I publish the pdf.
In the resultant pdf,the monochrome plot style is only applied to the orginal drawing that i opened (01) and not the others (02,03&04).
Any information that would assist me in resolving this issue would be most appreciated.
thanks.
Replies (24)
Message 2 of 25
maratovich
You need to change the new settings for printing monochrome in all layouts.
If there are many of them use Lisp or additional programs.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 25
Alfred.NESWADBA
as long as all sheets/layouts in these drawings do have the same format you can create a new (named) page setup, that has monochrome.ctb assigned.
In the PUBLISH-dialog you can then assign this page setup to all your sheets.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 25
pendean
Community Legend
Community Legend
Select each sheet then read the DETAILS section below,are they a 100% match?
Message 5 of 25
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 When you execute PUBLISH, select the "Plotter named in page setup" option.  Then you can use a named page setup you create in any of the files or even a template  to be used using the import function to apply it to the drawings.
John Vellek
Message 6 of 25
RobDraw
The key here is you need a NAMED plot style, not the default one. You really only need it in the top file in order to apply it to the others in the plot list.
Rob
Message 7 of 25
Llam.Tech
@Anonymous,
You missed one thing on the procedure. You should set and save a page setup.
Or you can watch my videos if you have time.
https://www.youtube.com/watch?v=77PnLzWKO60
https://www.youtube.com/watch?v=sDMvyrOicBM
Message 8 of 25
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Message 9 of 25
Thankyou  llamtech. I have tried repeatedly with autocad 2011 and trueview 2018 but with no success. I did manage to plot  to pdf once with 50 sheets but I wish to batch plot 194 sheets to 1 pdf with monochrome plot style. Now since plotting the 50 dwgs, I cannot even get that far. I hit publish but it gets part way through and there is no resultant file. When I tried batch plotting 194 sheets it got part way through then stopped. Don't know what next to try. If you need more info let me know. Thanks for your time.
Message 10 of 25
maratovich
Attach your file .dwg
www.kdmsoft.net
Message 11 of 25
john.vellek
Hi @Anonymous,
is it possible to ZIP a set of drawings so I can take a look?  I suspect that you might have some drawing corruption that could possibly be corrected using AUDIT or RECOVER.
I would also like to see how you have your page setup configured so i can try to apply it to a PUBLISH job.
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
Message 12 of 25
Hi John. Thanks for the reply. I have sent you an email
Regards
Wayne
Message 13 of 25
john.vellek
Hi @wayne.rand,
I finally received your files in my OneDrive folder. Sadly I did not have your CTB so I resorted to using the Monochrome.ctb.
I made a quick video that show how I set up my PUBLISH.  The resulting PDF completed successfully without errors and I added it to the OneDrive folder that we are sharing.
I hope this works on your side with the same settings and process.
John Vellek
Message 14 of 25
john.vellek
Hi @Anonymous,
John Vellek
Message 15 of 25
Hi John
Thanks so much for your assistance. I watched your video repeated the procedure using Trueview 2018 but the monochrome plot style was only applied to the first sheet. repeated the procedure multiple times with no difference. Don't know why that was so.
So then I tried your procedure using Autocad LT 2011 and finally had success !
This will be very handy for our business moving forward.
Thanks again for your advice.
Message 16 of 25
irmawati
@john.vellek wrote:
Hi @wayne.rand,
Thanks for the solution! didnt work out at first because the batch drawings was wrongly added from different folder. after correctly add the drawings it worked like a charm!
Message 17 of 25
I propose to consider an application for AutoCAD for batch printing drawings.
https://apps.autodesk.com/ACAD_E/en/Detail/Index?id=8185864542756779092&appLang=en&os=Win64
The application automatically detects drawing formats in model or paper space and prints them according to pre-saved settings including PDF and raster formats.
Message 18 of 25
maratovich
@Anonymous wrote:
It has long been and a lot of features:
>> click <<
But most users only want one button.
They do not want fast printing.
They want a lot at once, but do nothing.
They are paid for the time of work, and not for the work done.
Fast printing is a small salary for the user.
www.kdmsoft.net
Message 19 of 25
RobDraw
That is a very negative, biased viewpoint and very far from the truth. I feel sorry for you if this is even close to describing the people around you. It must be hard living in your world.
Rob
Message 20 of 25
Llam.Tech
@maratovich
I usually set my batch printing in the evening. I will run it, then go home. I still charge time, offcourse. Or, I can do my business outside the office, like walking or breath some fresh air.
I this helps. c,")
