APPCRASH AutoCAD 2016 StackHash
After installing AutoCAD 2016, on first launch I got the following error:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: acad.exe
  Application Version: 26.1.49.0
  Application Timestamp: 54d44341
  Fault Module Name: StackHash_d925
  Fault Module Version: 0.0.0.0
  Fault Module Timestamp: 00000000
  Exception Code: c000041d
  Exception Offset: 000007ff02d331d8
  OS Version: 6.1.7601.2.1.0.768.3
  Locale ID: 1033
  Additional Information 1: d925
  Additional Information 2: d925242518033024bc1ab6e97d4e9374
  Additional Information 3: ff12
  Additional Information 4: ff120cffde3fa6fe822103ed04f21efd
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Previously installed versions that were working earlier that day (AutoCAD 2015), will no longer launch as well without getting the same error message.  Tried unistalling all autodesk programs from the computer and reinstalling AutoCAD 2016 with same result.  Any suggestions to solve the problem would be greatly appreciated.
dmfrazier
Here's another post that looks similar to yours:
http://forums.autodesk.com/t5/autocad-electrical-general/application-has-stopped-working/td-p/550624...
What OS are we dealing with?
Tried "Reset Setting to Default" and got the folling error message.
Problem signature:
  Fault Module Name: accore.dll
  Fault Module Version: 20.1.49.0
  Fault Module Timestamp: 54d4450b
  Exception Offset: 000000000009d430
  Locale ID: 1033
  Additional Information 1: 8cb8
  Additional Information 2: 8cb8e200adf6a4f5d7d044dfb662ad8b
  Additional Information 3: 111b
  Additional Information 4: 111be8b47b481e17111cd0b43f3b783c
The fault module name changed from StackHash to accore.  I am running on Windows 7.  Any other suggestions.
dmfrazier
I think the previous link mentioned something about a graphics driver update, which may have been the actual resolution for that particualr issue.
Upon futher research it was discovered that there was an issues with the video driver.  AutoCAD was being ran through Parallels on a Mac, and the latest Mac update did not translate correctly with Parallels, causing the video driver in Windows 7 to appear not to be compatible.  Upgrading Windows 7 to Windows 10 resolved the translation issue of the video driver and solved the problem.
dmfrazier
"Upgrading Windows 7 to Windows 10 resolved the translation issue of the video driver and solved the problem."
Good news.
However, just beware:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Windows-10-support-for-Au...
