AutoCAD Forum
Any way to serialize the numbers while pasting text objects?
2 REPLIES 2
Ali-pk
634 Views, 2 Replies
Good afternoon,
Is there a way to serialize numbers while pasting? As seen below, I have pasted a red colored text called" I:1/0". Instead of pasting one by one, I have made the process faster by copying 5 and pasting 5 at a time, but I still need to go back to each one and change the numbers (starting from I:1/0 - I:1/15, then restarting at I:2/0 - I:2/15, and so on). So is there a way for the numbers to automatically increment and restart as I have mentioned? Thanks.
2 REPLIES 2
john.vellek
in reply to: Ali-pk
Hi @Ali-pk,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Yes there are ways to increment the numbers. Check out the TCOUNT command in the Express Tools.  This allows you to pick the numbers in sequence after they have been placed. There might be some add-ins in the customization forum or in the Autodesk App Store that let you do this as you place the text.
John Vellek
Ali-pk
in reply to: john.vellek
Excellent, I got it to work. Thanks! Have a great day.
-Ali
AutoCAD Inside the Factory
