I am with the US Coast Guard. We have thousands of 'hard copy' drawings in our repository that are still active. Yes, we have boats over 40 years old still in the water!
I have read through many of the PDF to DWG posts and I am probably going to repeat something already posted... sorry. I have tried a few PDF to DWG programs (Trial versions) with no real success.
I am trying to develop an efficient way to edit our Mylar drawings in CAD without having to do a full CAD conversion of the whole drawing, so I want to bind a PDF to the CAD file so that it can be more easily edited and digitally retained so that we can eventually eliminate our hard copy library.
In a nut shell, I am looking for a way to permanently bind PDF to a CAD file as a Vector image (although reading a lot here it seems this is not possible), and looking for the best way to erase/delete/hide revised or removed data.
Caveats:
1) the PDF cannot be a external reference (this is due to limitations with our Digital library program)
2) It has to be a vector image. Zooming into a raster causes too much pixilation.
3) It can’t be a proxy graphic
Currently what we have been doing is:
1) Create a good scan of the hard copy Mylar to PDF.
2) Open the PDF in MS Paint to remove unwanted lines, text, large speckles and blotches, etc…, and save the PDF. (this is actually pretty quick and easy to do)
3) Insert the PDF into CAD and work to get the scaling right
4) Add new data using AutoCAD
5) Once saved as a new PDF, the CAD file with the inserted PDF are deleted. The new PDF is now the latest digital revision of the drawing.
Steps 2-5 are repeated when the next revision is done. This method is time consuming. We do retain all previous revisions so anything erased or deleted can be recreated off of old revisions.
Any tips, pointers, and suggestions would be greatly apreciated!!!
