AutoCAD Forum
Annoying Bug
4 REPLIES 4
449 Views, 4 Replies
Annoying Bug
My AutoCad 2017 bar keeps changing its position all the time. I do not know exactly why. This slows me so much because each movement I do makes the space between the lower bar (with the coordinates) and the model view to be larger or smaller. I don`t know how to solve it, if anyone knows please tell me.
Isaque
4 REPLIES 4
imadHabash
you can arrange your CAD screen with tool palettes and any customization option that you need.just arrange your items as you wish then go to workspace settings icon (see attached image) and save it with unique name . by this you will keep and save your workspace as you wish and for all the way.
also you can change and select any other workspace and do alot by WSSETTINGS command.
Good Luck..
Imad Habash
Alfred.NESWADBA
...if @imadHabash's valid suggestions does not help ...
>> My AutoCad 2017 bar
Can you please describe or show a screenshot what is meant by "AutoCAD 2017 bar"?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Justin_Doughty
Right Click the Layout tab and Dock above Status Bar:
Justin Doughty
Cadline Ltd.
Blog | Twitter
in reply to: Justin_Doughty
Thanks for the help!
AutoCAD Inside the Factory
