Annotative text, not rotating with the Model Space [Plan + UCS command]
michalGVBNA
michalGVBNA
Hello Everyone,
I am using annotative text and as much as I am loving the auto rotation to viewport, I have stumbled upon a quite annoying problem. If I rotate the model space using "Plan command" the text does not rotate with me and stays stuck to the World UCS.
Does anyone know how to make the text follow your Model Space orientation or the UCS orientation?
Thanks a lot,
Michal
vinodkl
You need to check you text style and see if you have enabled the text to match orientation of layout.
Do to that type in the command "ST" and select the style which you have used and then uncheck the option "Match text to orientation" and then click apply.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
cadffm
@michalGVBNA
not possible
The oriantation is always the WCS, in model- and in paperspace
@vinodkl
This question is about MODEL tab.  And the option is on.
I edited the content  in detail
Sebastian
michalGVBNA
Thanks a lot for prompt reply @cadffm . I guess i will have to adjust the text through viewports...
Have a great weekend!
