Annotative Text in Tables
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
I have seen posts going back to 2014, saying this is not possible
and that there is no annotative text in tables
Can anybody confirm that this is indeed the case.
I work in autocad 2018 I can't do it.
I know someone who has autocad 2020 and also can't do it.
So when working with tables does everybody just use non annotative text at the correct height value?
Mike Kovacik
Joburg
South Africa
pendean
Community Legend
Community Legend
TABLESTYLE command does not offer an Annotative option, so nothing has changed through AutoCAD2021.
MikeKovacik4928
I don't use tables very much, so can't comment from a viewpoint of continual user.
However it seems to me that if you are going to set your cell width and height you might as
well just set your text height as well without worrying about annotative text.
Also it depends whether you put the table in model or paper space.
If for some reason, you wanted to put it in model space, you could make the whole table
as an annotative block.
I don't know whether annotative scaling in tables would be useful, and seeing as there is no
"ideas forum" for autocad like there is for inventor, there is no indication of what users think
or supporting votes.
What do you other users (those that use tables) think
Useful
Not Useful
Mike Kovacik
AutoCAD 2018, Inventor 2018
Joburg South Africa
RobDraw
You've answered your own question.
What use would annotative text in a table have other than to mess up the table. The entire table would need to be annotative.
Rob
MikeKovacik4928
Rob
I agree totally, that is what I thought too
I am going to end this discussion now with an accept as solution
Mike
