Annotative Text and Annotative Multi Leader Text.....
I just starting using annotative text and it seems to work great sometimes.
But, i'm having some issues with the Annotative text while using Mult Leader Text.Both the text and Multi leader setting are set for Annotative. But, when I add Multi leader text in a 50 scale plan, that same text shifts in the 20 scale plan and in some cases the leader change direction. The leader starts off on the left side of the text in the 50 scale and then switches to the right side of the text in the 20 scale.
Part of the problem seemed to be with text that was converted to annotative. But, after replacing the old text with new. It seems to still be giving me problems.
Any input would be great
pendean
Community Legend
Community Legend
Any chance you can post a DWG file here with that problem?
I replaced the older text with new text and it worked on some text. Then I would adjust the other text in the 20 scale and it seemed to stick,
I would like to know what the problem is.
Sorry Pendean I would rather not upload the drawing. I know you want to help. But, the project is a major US airport and its company policy not to share the file with anyone other than the client.
Thank You
pendean
Community Legend
Community Legend
can you recreate the problem in a new file with nothing pertaining to your client in it? If you can't recreate the problem in a new file I suggest you INSERT the problem file in the new file and continue as always.
