Annotative scales in Xrefed Drawings not updating
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I've set up an Annotative dim style and assigned scales 1:1 / 1:2 / 1:5 / 1:10 so that i can set up some detail drawings and re-use the dims instead of adding multiple layers of dims. I've tested everything is working in Sheet 1 of 2. However when i Xref Sheet 1 into Sheet 2 the dim styles in sheet 2 of 2 don't update the scale depending on the active scale like they do in sheet 1 of 1.
Is there a way to resolve this or should is the only way to freeze the layer and copy the dims live into the active drawing?
Tried looking on the forums for something similar but couldn't find a solution.
Tom
