Annotative scale boxes. Seperate msapce sales within the boxes.
Let the user define areas of the mspace with Boxes that have different mspace scales.
So a person could have different areas for their details at say a 1"=1' scale, while another area set for their profiles at a 1"=40' scale.  While the areas outside of these boxes would still be at the current global mspace scale.
Bill Neuhauser P.E.
Managed Design
john.vellek
Hi @Anonymous
I love this idea - I don't know that it would necessarily have to have "areas" or "boxes" but this would be SO handy for users that have to set up details and lots of different scales in a drawing. i don't know about you but I use the multiple grid setup in modelspace to reflect a detail's location and scale in paperspace. It works but sure could be improved.
Thank you again for suggestion how we can improve the product.
You are also welcome to contact the product team directly through the Product Feedback page. The links below go into more detail about the best ways to make suggestions.
How to provide feedback on Autodesk products
Raising enhancement requests for Autodesk products
Another great option is to participate in the AutoCAD Customer Council. This is an opportunity for our customers to partner with the AutoCAD development team to improve future releases of AutoCAD by giving continuous feedback on ideas, designs, and early builds.
In order to get involved email [email protected] or [email protected]
John Vellek
pendean
Community Legend
Community Legend
Q: is there a challenge with doing the same in paperspace? Are you aware of the VPMIN and VPMAX commands that come in handy for truly draft inside viewports in paperspace layouts without the hassle of staying in paperpsace?
That is EXACTLY what paperspace is for.  Why do the same thing in modelspace when the feature is already available in PS??
RobDraw
Actually, paper space came out way before annotative scaling but it does allow you to print multiple scales.
Working through viewports does exactly what is desired.
Rob
Issues I have run into is that while you're in MSPACE working on your design, you'll have your plan view and profile views in an area that your'e jumping back and forth working on and then you may have your cross sections in another area.   Now your plan & profiles maybe best viewed at say 1=40, while to too see your cross selections they were inserted at say a 1=10 scale.    So either one area will look proper while the other won't.
Detail dwgs could be close to the same.
Bill
That is precisely why you don't work in MSPACE, you work in PSPACE and change the zoom scale factor in the viewports to present the view as needed.
EVERYTHING in MSPACE is real units, nothing is scaled in MSPACE.  In PSPACE change the zoom scale factor of the viewport by selecting a scale from the pull-down in the properties window and off you go.
