Annotative leaders appear in paperspace, but won't plot
Hi everyone!
I'm a student, and this is my first shot at asking the Autocad brains for help!
I'm working on my final project and was successfully able to get my leaders to become annotated properly in all my various viewports. The issue is is that they won't plot. They do show up in my viewports, and I've checked to make sure they weren't on the Defpoints layer. (For some reason after I applied the annotative scales to all of my drawings, they all went on the defpoints layer? - but I switched them to another.) I made sure to set the ANNOALLVISIBLE to 1 and that did not fix my problem either. I'm not sure exactly what that means, but I read around in the forums and that seems to be the common issue, but that isn't what's happening here. Should I try to set the ANNOALLVISIBLE to another number? Or is there something else I can do? I should add that I created entirely new viewports, and that did not fix the issue.
Can anyone help? I'm able to send drawings or screenshots if that is helpful. Thank you!!
pendean
Community Legend
Community Legend
Share with us your DWG file, point to the leaders that do not print.
I found my issue. "Plot" was marked as off in the layers properties.
