I've got several drawings xrefd into a single drawing file.
Each drawing shares a hatch pattern for "native soil". The hatch settings are a hatch pattern scale of 10 and angle of 0 degrees.
Each xrefd drawing is a different size in dimension (ie. one might be 10' in length and another drawing may be 40' in length)
I've set the hatch patterns to be annotative in each of the xrefd drawings, and made sure the appropriate scale is reflecting the viewport scales that each one is represented in.
In layout/paperspace, I want all native soil hatch patterns to display at the same size.
My issue is that they are not all displaying at the same hatch pattern scale size when plotted, even though all of them have the same hatch pattern scale size. Larger-dimension drawings are showing the pattern teeny-tiny, while the smaller dimension drawings are showing the same hatch pattern in a much larger size.
Here's a pdf of what I'm working on:
