Annotative hatch angle changes while plotting
Message 1 of 23
We have set up a drawing with annotative hatches. The UCS of the drawing has been changed from world coordinates, and it is xref-ed into another file.
The base CAD file(D1), and the drawing it is xref-ed into (D2) are both set to this UCS in model and paperspace.
We are trying to print our drawing from the paperspace on D2. On screen, the hatches appear as we have set them. However on printing, the angle of the hatches change!
Cannot figure out what the issue is!!! Any help will be appreciated.
Sroboshi
Replies (22)
Message 2 of 23
kadmonkee
have you tried using (mvsetup)
if you leave world coordinates on and create all your model space elements (D1) then xref into D2 in paper space viewport use MVSETUP to orient your view as needed.
another option - test the view in D1 create a viewport in D1 and set your scale for the viewport to match
settings from D1 and D2 may be different
in your Xref (D2) select the viewport and check settings
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 23
Thanks for your reply.
I've tried them both. Neither seems to fix the problem.
What I do not understand is how it appears at the correct angle when on screen, but the hatch angle changes when printed??!!!
Message 4 of 23
kadmonkee
are you printing to PDF or directly to a plotter?
there may be settings in the drivers causing this.
thank you
Message 5 of 23
I've tried printing to the plotter directly and as pdf - both seem to have the same problem.
Message 6 of 23
kadmonkee
can you share the drawing ?
thank you
Message 7 of 23
I've created a stripped back version of the drawing which has some of the linework and hatches. The problem still exists.
Will really appreciate any help on this!
Message 8 of 23
john.vellek
Hi @Anonymous,
I suggest that you first preform a little drawing maintenance: Audit, Purge, -PURGE>Regapps (over 11,000 regapps).
I switched the print device to AutoCAD PDF (General Documentation) and the hatch retains its orientation.
John Vellek
Message 9 of 23
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 10 of 23
Hi John,
Thanks for your message. However it hasn't solved the issue. Purge-regapps has definitely cleaned up the drawing, but the hatch angle is still off while plotting. I've tried a few plot devices as well including the AutoCAD pdf, they all print the same!
Message 11 of 23
john.vellek
Hi @Anonymous,
I am sorry it didn't work on your side as it did on mine. I suggest that you create a new user account on your computer with administrator permissions. Logon with the new account, start AutoCAD (without any customizations) and see if changing the plot e device to the AutoCAD PDF  corrects the problem.
I will take a look again at your file and see if there is anything else that I might suggest. Thanks for your patience.
[EDIT] I looked at both the D1 and D2 files again.  In each, I ran Audit, Purge, and -Purge>Regapps. I then saved each and reload the xref. With the AutoCAD PDF driver selected, I plot to PDF and the hatch is retained in the designated angle.
I have attached my versions of your files for you to try on your side.
John Vellek
Message 12 of 23
john.vellek
Hi @Anonymous,
Have you had the opportunity to try the files I attached? I am hoping that my suggestion  will fix this issue for you.
John Vellek
Message 13 of 23
Thanks John.
Tried everything but it nothing seems to work. We've tried opening the file on a few computers in the office, but the problem doesn't go away. I have now gone back to using NON-ANNOTATIVE hatches on this drawing and this has resolved the problem for the moment, not ideal though!
I'm guessing the problem is to do with annotative hatches then, wondering if there's a system variable that I need to set right?
Message 14 of 23
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938...
This is something I've just come across. Does this mean that annotative hatches do not work with a rotated UCS?
Message 15 of 23
john.vellek
Hi @Anonymous,
This article refers to the view being "twisted".  Annotative Hatch objects  will always match the orientation of the layout.
In re-visiting your D1 file, the hatch does seem to retain orientation until you perform a REGEN.
If you rotate the view, the annotative hatch will remain in the orientation to the layout  and not the model geometry. This doesn't always show up instantly but a REGEN should force it to show up the way it will plot.
Does this make sense?
John Vellek
Message 16 of 23
Hi John,
I need to rephrase my question I have realized.
We always create our live CAD drawing in one file, and then xref it into another blank file where we create the drawing to be printed with title block etc. I have now realized that the hatch orientation changes in paperspace viewports in the live drawing itself, as well as the file into which it is xrefed. The hatch orientation change has to do with viewing the drawing in a viewport. A regen straightens the hatches, but a second regen again changes the orientation.
Given that we rotate the UCS on most drawings to make it work better on the sheet, we are unable to use annotative hatches because of this. We have only recently started using annotative hatches, and I feel like I am missing something quite obvious.
Message 17 of 23
john.vellek
Hi @Anonymous,
I see in my previous post that the article I referred to did not get retained when I put in the URL. I have not yet rediscovered where it is located. I did add a URL link though to a video which reiterates that the Annotative hatches will realign to the layout.  With this said, I suggest you use a traditional hatch for this operation.
John Vellek
Message 18 of 23
sroboshi.das
Hi
I seem to have finally found the solution to this.
Hatch orientation was changing in viewports where the UCS was set to anything other than world.
1. Set SAVEFIDELITY=0. This is because older versions of CAD (older than 2011) do not seem to be fully compatible with annotative hatches. Also, we have changed the default save settings to save at 2010. Anything older than this still creates problems.
2. All objects must be hatched in the same UCS in which the viewport will be set up. (The only constraint is that viewports with varying UCSs still have the same issue).
Sroboshi
Message 19 of 23
CADmgrMike
Just and FYI that this discussion helped with a similar issue I'm having.
In the case of the AR-CONC hatch, with annotative hatching and a rotated viewport, the hatch triangles will blow up also.
Mike Porter
https://provostandpritchard.com/
Message 20 of 23
Have anyone solved this issue yet?
I'm having same issue.
- hatch is annotative
- annotative is turned on
-model space is in world ucs
-each viewport layouts are all rotated, have different ucs
-hatch displays correct orientation to world ucs on model space and viewport layout ucs on screen
but when it is printed, hatching angle only print to world ucs orientation
doesn't matter if it is printed by one sheet or published with multiple sheets..
hatching orientation will not maintain the angle to viewport ucs
