I often work with in meters, millimeters, and inches and it would be wonderful to have a single annotative legend with which to work from. It almost seems as though this functionality is possible but disabled by AutoDesk for some reason?
From what I've gathered if I had a legend with non-annotative blocks and have my -DWGUNITS and INSUNITS set correctly the blocks will autoscale as required. Its a little finicky to get working but I've been able to do it. However, if the blocks are annotative (as I want them to be) they ignore INSUNITS as indicated in help...why?! I am having difficulty even understanding why this would be so.
How do others deal with this problem? If I only worked in mm (or any other unit) this wouldn't be a problem and honestly if this was an option available to me I would take it. I have found a tool palette solution in which I would have to set tool palette properties to scale the block by a specific value which I feel is what INSUNITS would/should do and is designed to do...
I was of the understanding that this autoscale feature does not work in conjunction with Annotative and Dynamic blocks. Am I mistaken? I want to be mistaken!
From all my searching and testing it is only possible if you are not using annotative and/or dynamic blocks which, from my perspective, defeats the purpose of this feature...
Honestly, I agree with you. My preference is to have all the legends seperate and have them contain all the tools I would require for the drawing units I am working in. I feel as though the extra work required to manage a legend for each unit type is outweighed by the convienence of having the correct dimstyle, tablestyle, mleaderstyle, and so on.
I am investigating this at my companies request as they would prefer that I only had to manage a single legend and I am attempting to comply.
@pendean wrote:
Settings (and content) in your file will govern: if missing, what you bring in governs and may be resized accordingly.
AutoCAD has an archaic 'units' method of calculating 'scale': it makes no distinction between mm and inches or miles or kilometers. You should not really mix-n-match if you can avoid it, IMHO your mm library should be separate from your inches library.
Why? Why should I have to make and maintain two separate block libraries? If I update a dynamic block later, then that means I would also have to update the metric or imperial equivalent block.
I would love to work in a metric only environment, unfortunately I am Canadian and find myself working for companies all around the world, including american ones. That means I end up flipping between imperial and metric constantly.
