Annotation selection list not responding to mouse clicks
when I start a drawing with some of the default templates in AutoCAD 2017 I am not able to click the Annotation Scale Factor list in the toolbar and choose a scale factor from the list.  This behavior only happens with some of the default templates. For example I am not able to click and select from the Annotation Scale list when I start a drawing with the ACAD3D.dwt. But when I start a drawing with ACAD.dwt I can click and select from the Annotation Scale Factor list.
I think this is because of a drawing variable somewhere. I have replaced the ACAD3D.dwt from the web which does not change the behavior. All the drawing variables I can find look to be set to there defaults.
Thank you for any help.
WarrenGeissler
3D Won't allow annotation scales in Perspective mode. Right-click your viewcube and change to Parallel mode to get to annotation scales (or set PERSPECTIVE = 0)
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
imadHabash
it will be fixed if you change your workspace to 2D wireframe then press the icon ( as showb below ) . after that if you get back for any workspace it will still work .
Imad Habash
