AutoCAD Forum
Animation Help in AutoCAD 2013
3 REPLIES 3
306 Views, 3 Replies
Hey everyone,
So I am going a plating project in standard AutoCAD 2013 at work and want to animate the process. I have each step in the process already drawn in 3d and on different layers that I can turn on and off as a slideshow, but is there a way to animate the growth of the metals and the entire procedure without me manually going in and turning the layers on and off?
Also, can I do this for multiple views at the same time, like with different camera angles?
3 REPLIES 3
pendean
There is no such ability in AutoCAD.
in reply to: pendean
Yeah I kinda figured that, I've been looking all over the menus and haven't seen anything. I probably would need "MAYA" for that wouldn't I?
dgorsman
3DSMAX would be a smoother import (it's also including in many of the Suites and Collections).  Navisworks Simulate may be a bit easier to work with.  The animation tools are much more basic, but it's an excellent middle ground, especially if you have mixed content from different sources.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Technology Administrators
AutoCAD Beta
