AutoCAD Forum
All my circles in my drawing all turn to ellipses
4 REPLIES 4
daveshepherd
292 Views, 4 Replies
Hi All,
I was just drawing away, and when I looked up all the circles in the drawing had turn to ellipses. I must have
entered a wrong command at some point while I was looking away. I hit regen a few times but to no avail.
Also one more thing, when I use the trim, extend and erase commands, it only does what's in the drawing window
where as before, it did all the trims, extends and erases all that is highlighted.
Any help in any of these questions would be much appreciated
David Shepherd
Northern California
4 REPLIES 4
Washingtonn
in reply to: daveshepherd
select one and see if in fact they are ellipses and not circles with an odd aspect ratio.
Kent1Cooper
Did you shift out of plan view?  You might have accidentally touched Shift while panning by pressing the mouse wheel, which would take you into viewing from some direction other than just straight above.
PLAN command, accept current as default.
Kent Cooper, AIA
daveshepherd
in reply to: Kent1Cooper
The Plan Command worked, Thanks so Much
daveshepherd
in reply to: Washingtonn
Thanks for your quick response to my Cadd question.
It was suggested that I try the "PLAN" command which I did
and that corrected the Problem.
Technology Administrators
AutoCAD Beta
