Aligned dimension not readjusting automatically after polyline modification in AutoCAD
dev603_tech
Observer Observer
dev603_tech
Observer
Observer
In Drawing File 1, I created a polyline and added an aligned dimension to it. When I modified the polyline height, the aligned dimension line updated automatically as expected.
In Drawing File 2, I created a similar polyline and added an aligned dimension. But when I modified the polyline height, the aligned dimension did not update automatically.
Is there any drawing-specific setting I need to enable so that dimensions update automatically when the associated object is modified?
Kent1Cooper
That sounds like the two drawings have different values set into the DIMASSOC System Variable.
Kent Cooper, AIA
