AGE Command/Exporting
I work with 80/20 Aluminum extrusion on AutoCAD through the AutoQuoter XII software. I've continually had issues exporting .dwg files to .iges formats, and I'm not sure how to solve them.
- Exporting causes each component to become one single components, rather than individuals
- Running the "AGE" command to take the frame components down to their basic form doesn't always work and I get this message
 - Most of my customers used Solid Works, so importing/exporting has become increasingly more difficult
Can someone help me out?
john.vellek
Hi @Anonymous,
Can you share one of your AutoCAD drawing files? I would like to see how it is constructed and the results I get when I do  an export to IGES.  Also, do you see the same error if you remove the AutoQuoter II plugin?
John Vellek
