- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi again all,
I just posted not too ago about a query regarding block editing but this is relevant to something that will overall save many hours of time in my projects so I would appreciate any assistance provided.
Again, I will describe this descriptively to ensure there are no grey areas or room for confusion.
My question regards the technical uses of polylines and the lengthen command. In simple, I am looking for a way to hide linetype properties of polylines but only for certain parts of the polyline.
I will now go into as much detail as I can. Imagine a main polyline which has many sub-polylines branching off of it.
If both the main and sub-polylines have identical linetype properties (ie. dashed, numbered, lettered) then naturally, all their properties will clash, especially in the cases of numbered or lettered polyline linetypes unless they all have the same lengths or by sheer coincidence they happen to avoid clashing. Currently, I would have to measure from the end of each branch to the source of the main polyline, but I wish to use the lengthen command on the end of each branch to save a lot of time. Is there a way to hide the linetype properties of all the branched polylines whilst it is on the same route as the main before they separate to avoid those clashes?
Again, I can just draw the branches at their separation point but I need to measure the distances of these branches, I am going to try start writing a LISP script that has the logic of (if branch layer of polyline overlays with main branch layer of polyline, then disregard linetype properties of branch layer, else always display the branch layer linetype properties).
I may not have explained this perfectly but I hope you understand where I am coming from, if not please do not hesitate to ask questions. Any help would be greatly appreciated.
Signed,
MN
