I just lost an old computer due to failure. Bought a new one - Yay! Installed ADT 2005, and I seem to have incompatability issues. My new computer runs Windows 8.1. Seems that ADT 2005 is incompatible, yet Autocad 2004 or 2005 is not. Is there any way to run the autocad 2004 program that is apparently inside ADT without actually running ADT so that I can keep using this seat?
Solved by pendean. Go to Solution.
.dll files stand for dynamic link library, It's how the applications runs through your system.
When it say's it couldn't be found, it most likely crashed because directory standards no
longer line up. I recommend you run an xp simulator to get the older application to run.
