Hi Im gettging this on the LMtools on the server and cant figure out how to fix it, Ive googled the issue and tried some of them but still doesnt work
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: CEI-SRVDATA
License path: 27000@CEI-SRVDATA;
FlexNet Licensing error:-97,121
Thanks Rudy
rytech@rytech.ca
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
Please try the steps below to make sure to update your license file, this error indicates that your license file can not be read.
A license file first needs to be generated or requested here:
1. Generate a Network License File in your Autodesk Account or Requesting a Network License File
Note: In the case where you have combined the license with an existing license file (make sure to check for copy/paste errors)
*If you need help Finding Your Host Name and Physical Address
Then, the NLM needs to be installed and setup:
2. Make sure you meet the NLM requirements to Install & Configure it
3. Then, on each Client computer at launch, specify a License Server "2080@ServerName"
If you have done all of the above, Start/Stop the NLM Service
Keep us posted.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Try this other method, Requesting a Network License File.
If you can not request a license file with that link, let me know I will turn this post into a case to get you a license file with the proper support team.
Natasha
Helpful Links:
Hello @Anonymous,
Just checking in with you, where you able to request a license file with the link provided?
Natasha
Helpful Links:
Yes, confirmed.
I had two cases this week where this was the solution. A proper license file was causing this issue somehow, and generating an identical replacement file solved the issue. Thank you, @natasha.l 🙂
