Adding Hyperlinks to pdf
I would like to know if there is a way to add internal hyperlinks in PDF through AutoCAD 2021. I am creating a document with many pages (more than 300 pages) of electrical schematics and I need an index page in text form that refers to each page. A clickable link in the index should navigate to the referenced page. Is there anyway to do that in AutoCAD 2021?
Patchy
Never seen that option in autocad.
pendean
Community Legend
Community Legend
AutoCAD does not do "pages" when printing or plotting: are you using plain AutoCAD 2021 or a vertical?
You need a PDF editor to do that after the fact as an option.
timothy_crouse
Yes, you can add hyperlinks that create quick navigation links to designated pages.
This answer is applicable to single file multipage PUBLISH outputs and sheetset single file output files.  Each layout you add to the plot / publish que is treated as a separate PDF page.  The named views will appear in the navigation pane.
Best Regards
Tim C.
