AutoCAD Forum
Adding a multiview block to a tool palette
5 REPLIES 5
1134 Views, 5 Replies
Hi! I can drag and drop a usual block to a tollpalette but not a multiview block. At the same time there are readymade palettes that contain multiview blocks so it should be possible to get them there. Is there a simple way to do that? Thanks beforehand!
5 REPLIES 5
knmdk
You can do this easily with AutoCAD 2013/2014/2015 for sure. Same good-old drag & drop as with regular blocks.
in reply to: knmdk
Unfortunately I can not confir this behaviour on my computer. I tested both on AutoCAD 2014 and Civil3D 2014. It works like a charm to drag and drop conventional blocks to toolpalettes but no luck with multiblocks. Please see the attached images.
sbrusco
Hi Viktors,
By "multiview" blocks, do you mean dynamic blocks with a visibility parameter? If so, i can drag and drop them onto my tool palette. Of course, you need to make sure the TP is not write protected.
Sal
in reply to: sbrusco
Hi! What I mean by a multiview block is a block that can be created by _AecMvBlockAdd command. Just noticed that the command is not available in vanilla AutoCAD. I created the block in Civil3D and it is recognized even by AutoCAD. The object type that is shown in the properties window is AEC_MVBLOCK_REF. I finally managed to get it onto a toolpallette by exporting the block to a separate drawing (WBLOCK) and then drag-dropping the resulting drawing onto the pallette.
asikora_frazedesign
I had the biggest hassle trying to get this to work.  What finally worked for me was to do the following
  • Open the Style Manager from the Manage Tab
  • Expand Multi-Purpose Objects
  • Expand Multi-View Blocks
  • Select then Drag each Multi-view Block one at a time to the tool pallet.
AutoCAD Inside the Factory
