Adding a flat surface to a Cylinder
hey guys,
i need to figure out how to add a flat part onto my cylinder, its so a bolt can go through the hole and instead of sitting up against a round surface it will sit flush with a flat one.
any idea?
-FDC-
Subtracting or Union an extruded rectangle will do the trick I think.
Can you post your drawing ?
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I agree with @-FDC- that a box could be subtracted from the cylinder face. I don't know the exact sizes or orientation but I made a quick video that I hope helps with the process.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
