It would be a time saver if there was an indication in the pop-up context menu when you hover over the endpoint grip of a polyline that alerts you to the fact that it it needs to be reversed before you add a vertex. And the ability to perform that reversal should be in that menu instead of having to select the polyline and running down a another context menu and then a fly-out menu.
Yeah... someone should think more about that feature when he developed it. Unfortunately, there is no way to change or add little something to make that built-in feature work as one would expect.
The only way really is to forget about it and move to some LISP - as there are few just what I know that does Polyline-Continue. You can add it to the classic shortcut menu but NOT to the hover-one.
Just search for it...
I have a routine called PolylineContinue.lsp, with a command name PLC, available >here<. It will work off either end of an open-ended Polyline, without reversing for either. And it will even let you go into arc mode and start with the tangent direction off the end you pick near.
Nothing is really unique. Just simple polylines that I revisit to continue their paths into various directions. The program would know that one of my possible intentions is to add a vertex whenever i hover over the endpoint grip. And thanks for the link to the customization forum.
I sometimes use p-line continue - or at least some version of it. But I wish it would automatically join the new pline to the existing one.
My PLC command does that, provided you end the command with Enter/space [or with Close], not with ESCape.
Release 2023 has provided exactly what I was looking for: "A new grip option, Extend Vertex, adds a new vertex to your polyline extending from the selected end grip. You no longer have to reverse the polyline direction. "
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-423E92B6-F580-4A43-A543-80C84080BF5D
Thank you Autodesk!
