Add revision information in AutoCAD drawing
Jaminn1
Jaminn1
Community Visitor
Community Visitor
Hi, i want to add update/revision information in the title block and the existing text is inserted using enhanced attribute editor, when i double click it opens a window and all the changes are made there. how can i add similar text with new revision. thanks.
paullimapa
the feedback from this recent thread should assist you in modifying the existing title block to add more attributes:
Solved: Re: Listing Attribute Information To Edit - Autodesk Community - AutoCAD
Paul Li
IT Specialist
@The Office
dany_rochefort
@Jaminn1 Usually people will nest the revison attibute within the template block and have like 5 lines of attributes for each revision. It's a big pain in the arse to make and manage bascially.
My trick is to make 1 generic revision attribute block and not nest within the template block so you can just copy the same attribute multiple times. Way less fuss to make and manipulate.
