add object to group
add object to group
jdfnnl
add object to group
jdfnnl
I am using Acad 2015 which does not have a dialog box for the 'group' command. Is there a way to add / remove objects from a group with this version? I am trying to use groups to build a complex selection incrementally. Or is there another way of saving selections that might be recommended?
cadffm
AutoCAD2000 don't have a Group-dialog, but 2015 does
[F1] CLASSICGROUP
Sebastian
jdfnnl
Is there a command for the dialog, because 'group' is command line only with no add / remove options.
imadHabash
To Add or Remove objects From a Group
  1. Type GROUP in the command line and press Enter.
  2. In the drawing area, select a group.
  3. At the prompt, do one of the following:
    • enter a to add objects
    • enter r to remove objects
  4. Select objects to add to, or remove from, the group.
You can get more Info from Here .
Imad Habash
cadffm
You should read my reply again  with more attention 😐
Sebastian
pendean
Community Legend
Community Legend
@jdfnnl CTRL+A to toggle grouping off, then erase what you do not want. CTRL+A to turn grouping back on. Now your GROUP is less that unwanted item(s).
To add an item(s) to a GROUP, just group them with the group again much like you always GROUP objects together all day long. So how do you do that now?
May I ask if you're using LISP for grouping yet (Assuming your 2015 is not the LT version)? Lots out there, see this discussion to get started https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/regroup-a-group-you-have-ungrouped-i...
and https://www.cadtutor.net/forum/topic/26473-group-command-routine/
Life's too short to do these the long way in AutoCAD.
