actual print size on the screen (considering a particular scale)
hi,
how can i  use the ZOOM SCALE command in paper space. Not the PREVIEW.
Example: 17-inch monitor, A4 paper, ZOOM SCALE = 1.65.
Note: For monitors of other sizes the ZOOM SCALE is different.
The above Scenario to have the actual print size automatically on the screen considering certain scale.
Actually i read about that and i don't know how to implement it . Could anyone help me and provide a screen shoots for that please?
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
To get what? And even more important, which display resolution, dpi scaling, ...
You can't compare monitor/display with paper, you can't set a zoom factor to be able to measure (with a ruler) anything on display to get the info about the length an object might have on paper. Just imagine how you would like to have an A0 paper displayed 1:1 on a 17" monitor.
Other situation: what will happen if you have a 17" monitor on your laptop + a 24" monitor as separate device and you have set the monitors to be cloned ... so you have the same display of a line (assume it's from left to right monitor border) ==> measure now that line on both monitors ==> different length on the ruler 😉 (next sample could be a beamer that displays your main display cloned, and the beamer changes it's distance to the presentation wall, also a proof that there is no "one zoom factor that makes a measurable length").
Use the command _DIST if you want to measure objects in AutoCAD  and understand a monitor just as a relative device.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Thanks Alfred.
Best,
Faten
