Action Recorder Tool doesn't work at all
Message 1 of 14
i just started to watch this tutorial how to use the action recorder tool but when i start using it it wont record any command and wont play it too.
Accepted solutions (4)
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
What version of AutoCAD does ABOUT command list as you having?
And what steps are you taking to record: explain what you do or click on etc.
Or is the problem you're not sure how to play back what you recorded? Please explain how you are doing the playback?
Message 3 of 14
cadffm
hmm
Press Record
Draw a line
Press Stop
Save the ActionMacro
Delete or move the line,
Play the Macro..
Isn't working?
Make a Autodesk Screencast and show us what you see.
Sebastian
Message 4 of 14
Message 5 of 14
cadffm
PLAY works, but recording doesn't.
Hmm.
Share a Screenshot of your command ABOUT dialog, we will try it in the same version.
Sebastian
Message 6 of 14
Annotation 2020-06-04 134601.png You mean this?
Message 7 of 14
pendean
Community Legend
Community Legend
Message 8 of 14
imadHabash
you have a problem in Recording !!! as you notice from MY below image , while recording you have to see in Action Tree all of your moves and actions and that is NOT exist in yours . this is why your Play is not active because there is NO actions already recorded . for Now i suggest to check from your Autodesk Desktop App if there is any updtaes needed .
Imad Habash
Message 9 of 14
I did my update couple days ago i don't think that's the problem.
Message 10 of 14
imadHabash
in reference to your message 4 screencast you can notice the issue .
Imad Habash
Message 11 of 14
pendean
Community Legend
Community Legend
You might need to remove and reinstall the application as your next step.
Message 12 of 14
cadffm
It  doesn't solves this problem if you (don't) think...
And there is no setting, your install is buggy.
Things you can try:
Reset to default
Repair install
Try it as Admin
Whatever it is, it isn't normal and nothing you can change inside the program.
Sebastian
Message 13 of 14
cadffm
Or in post#3 🙄
Sebastian
Message 14 of 14
I reinstall my CAD and the action recorder tool works now thanks
