Action Macro Record - Is there another way to record Autocad?
dany_rochefort
dany_rochefort
I am trying to record some autocad commands & techniques using the Action Macro Record function. Everything works, but the speed of playback is just too fast to see what is actually happening on screen.
This is for an Autocad capacity building project; whereby new users can consult short vidoes to see how to use different commands and techniques.
I am thinking that the Action Macro Recorder might not be the proper tool for the job !?!
Does anyone have any thoughts?
M_Hensley
For creating instructional videos I would check into the free screencast program from Autodesk.
https://screencast.autodesk.com/
dany_rochefort
All right, lets do this ! Thanks
Any solutions yet?
dany_rochefort
You can use the screencast application : https://screencast.autodesk.com/
It works, but the screen size to view the video is quite small, it's a bit hard to see what is clearly going on... But it works!
Good luck!
About recording Autocad, I like to use Joyoshare Screen Recorder. It can support to record all the actions on your screen with high quality. I think it is worth being used. Hope you like it too.
