AcLauncher.exe - System Error
when i traied to open saved autodesk file computer showing this error help me ASAP
wispoxy
Hello @Anonymous,
It seems Microsoft Visual C++ is causing you problems. The image below shows MSVCP110.dll but still applies to your MSVCP140.dll because it's in the same category. Follow the instructions, hope all goes well.
https://forums.autodesk.com/t5/autocad-forum/cant-start-msvcp140-dll-missing-and-mfc140u-dll-missing/td-p/6888203
-also-
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/The-program-can-t-start-because-MSVCR110-dll-is-missing-from-your-computer.html
Issue:
When trying to install, uninstall, or launch an Autodesk product or service pack update, a message appears about a missing MSVCR110.dll or MSVCP110.dll file, such as the following:
The program can't start because MSVCR110.dll is missing from your computer. Try reinstalling the program to fix this problem.
The program can't start because MSVCP110.dll is missing from your computer. Try reinstalling the program to fix this problem.
User-added image
Causes:
There is a problem with one of the Microsoft Visual C++ Redistributable packages installed on the computer.
Solution:
Uninstall and reinstall Microsoft Visual C++ (see How to remove and reinstall Microsoft Visual C++ Runtime Libraries).
