Accessing Electrical Toolset in AutoCAD 2021
Message 1 of 10
Hi all,
Does anyone know how you can access the electrical toolset in AutoCAD 2021? As a student, I can no longer download AutoCAD Electrical 2021 onto my personal device, but the site says that all of the electrical features are included in AutoCAD 2021. However, I cannot figure out how to access those features. Could someone please lend some guidance on that end? Thanks!
Replies (9)
Message 2 of 10
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
The Toolsets are included as part of the standard AutoCAD 2021 subscription, but they are still separate installations.  I am not sure if as an educational version the Toolsets are included, if they are you can access them under your Autodesk Account. Look for the item AutoCAD - Including Specialized Toolsets and select View all included items
Please click the Accept Solution button on any posts that resolve the problem or answer your question.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 10
rkmcswain
To reiterate - the term "toolset" is misleading.  It's still AutoCAD Electrical, you still have to download the entire install and you still have to install it separately.
For example, when you are in your account, you may see something like this:
Expand it, then click on "View included items"
Then you should see something like this, where you can access the download:
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 10
Thanks for the quick response. It unfortunately appears that the toolsets are not included for personal use.
Message 5 of 10
Are you accessing that page thorough the Autodesk website or the the AutoCAD app itself?
Message 6 of 10
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can access the downloads through the website manage.autodesk.com
All the best,
Cheryl Buck
Message 7 of 10
rkmcswain
@Anonymous
Note the differences in how AutoCAD is listed here:
Does yours match the top?
Message 8 of 10
Awesome! This all worked out. Thank you so much to both of you for the help!
Message 9 of 10
In the AutoDesk Get Products window, I don't have that "extended" version - I have installed AutoCAD 2021, but am still not seeing how or where to install AutoCAD electrical...?
Message 10 of 10
rkmcswain
@Anonymous - look at the image in post #7 in this thread. Which one matches yours?
