Access address bar in AutoCAD Save As dialog
mrshayboo
mrshayboo
Is there a way to access the address bar to paste a file path rather than navigating through all the folders.
There is only access to a drop down menu, meaning you have to navigate to the file you want each time, rather than being able to paste or edit the file path in the address bar.
lee_kirkup
Paste the path into the File name: box at the bottom of the window, then just add your filename to the end.
