ACAD LT 2015 + ACAD 2014 full
qfanatiq
qfanatiq
I posted a week or so ago about issues with 3D elements in our drawings (here https://forums.autodesk.com/t5/autocad-forum/flattening-help-full-ac2014/m-p/9064692#M995545).
I have painstakingly spent today taking apart blocks, recreating etc etc to 00 on Full ACAD 2014 as Flatten was working to a limited capability. However, I am still having issues.
Do I recall correctly?
I have a memory of an issue like this some years back, but I traced over/redrew and had something set that would NOT allow any of my lines to jump (snap) to any other Z value than 0,0 when drawing over.
I want to do this again, re-setup all drawings and blocks by using this setting to be secure in my redrafting of the various drawings. I ideally need something that works on both Full ACAD 2014 and LT 2015
Many thanks indeed.
Cheers.....Q
pendean
Community Legend
Community Legend
You can't automate diddly-squat in LT.
For full AutoCAD, it might be time yo started over in the LISP forum if the AutoCAD reality of inserting a problem file into a fully functional and fully equipped template file then saveas is not a fix.
Looks like you are trying to fix a decade or more of sloppy drafting in an office you just joined: it might be simpler (if an option) to just implement new content and procedures to new files/projects and let those old files wallow in their mess forever.
And lets not forget the most important fix: TRAINING, TRAINING, TRAINING for the staff that picked up and still do those old bad habits.
Good luck.
qfanatiq
Thanks again PD.
I've always used LT, there is quite a range of various ACAD's here.
I'm only here for a short while. At least I now have managed to convince of a redraw, just was hoping I could make it very quick and reliable.
We also get manufacturing drawings from others and they often mix SketchUp and Rhino (plus others) models that have/are causing issues.
Fun, fun, fun....
Cheers,,,,,Q
