- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a drawing that was created with AutoCAD version 10 (if I remember correctly). When I created this drawing I also created many different line types by "playing around" with the acad.lin file (using notepad).
I recently opened the original drawing using, our corporate wide, AutoCAD-2018. The drawing opens fine and I can change any line to any of the linetypes I created originally.
I now have a need to create a new linetype for this old drawing. I thought I could modify the acad.lin file as I have in the past. Unfortunately, when I open acad.lin file (using notepad) none of the linetypes I created are there, but the standard acad linetypes are there.
Is there a way to retrieve the linetypes information of the linetypes I created, from the opened (using AutoCAD-2018) drawing, and saving that information to the acad.lin file? I can see my created linetypes in the pull-down menu of the Linetype box of the General tab of the Properties dialog box.
HELP!!
