ACAD 2026 VP Line Type
BillAllenSE
Message 1 of 16
BillAllenSE
When I set a line type of a layer within a viewport (typically HIDDEN2), it still displays as continuous. This does not happen in 2023. Maybe I have a "custom setting" set that I've forgotten about.
How do I fix this?
Thank you
Replies (15)
Message 2 of 16
paullimapa
Could you share this dwg here for community to review?
Note the exact layer name & which vport if more than one.
Paul Li
IT Specialist
@The Office
Message 3 of 16
Kent1Cooper
Try PSLTSCALE = 0.  REGEN may be needed.
Kent Cooper, AIA
Message 4 of 16
BillAllenSE
PSLTSCALE=0 did not solve my problem. However, I have a clue!
I draw my floor plans on top of each other and change views by turning on and off layers. The annotation scale and standard scale is set to 1/4"=1'-0". When I set the linetype scale (LTS) = 1.0, which I've always done, the line work looks fine in one view port but, in another viewport, the hidden lines (HIDDEN2) appear solid. When I set the LTS = 48, the hidden lines appear correctly, but when I go back to the other viewport (where the hidden lines appear correct with a LTS of 1.0), the hidden lines appear solid. I have reviewed the properties of both viewports and I can see any differences.
Does that help with solving the problem?
Thank you
Message 5 of 16
paullimapa
What if you create a new vport?
Paul Li
IT Specialist
@The Office
Message 6 of 16
BillAllenSE
More clues!
If I create a VP on the same sheet as the one with LTS = 1.0 working and restore the layers from the offending sheet, it works. When I copy that VP to the offending sheet and restore the layers from the offending sheet, I still have the problem.
Message 7 of 16
BillAllenSE
If I copy the entire sheet and restore the layers, it works.
Message 8 of 16
paullimapa
Best way to help you resolve this is still what I posted before which is to share your drawing with this problem.
Paul Li
IT Specialist
@The Office
Message 9 of 16
BillAllenSE
Yeah, I'm not posting my DWGs to a forum. I don't mind sending it to you individually. I hope you understand.
Message 10 of 16
paullimapa
Sure send it to me only then. If there are xrefs involved make sure you use the etransmit command.
Paul Li
IT Specialist
@The Office
Message 11 of 16
BillAllenSE
I sincerely appreciate your offer and your time, Paul. I fixed the problem by copying another sheet and restoring the layers, so I no longer have the problem. I could download a backup and send that, but that's a little bit of work and, right now, I don't have the time to solve the curiosity I have about why the problem existed in the first place. It's funny (ironic, not humorous) how these types of problems pop up only when I have a deadline LOL.
Thanks again
Message 12 of 16
paullimapa
Glad you got it resolved…cheers!!!
Paul Li
IT Specialist
@The Office
Message 13 of 16
BillAllenSE
Hi, Paul.
My problem happened again. I tried what I used on the previous project (copying a sheet, changing the layer states), but that didn't work.
See sheet S-2. All of the layers from the xref Second Floor should be HIDDEN2 as shown in the layer properties. On my monitor, they appear as continuous lines even when I change the LTS.
I appreciate you taking the time to look at this for me.
Message 14 of 16
paullimapa
I've tested in versions from 2020 through 2026.
I'm able to replicate your problem starting in 2025 & 2026.
In prior versions like 2024, all I needed to do in drawing 22510 Plans.dwg on layout S-2 is to enter the following:
PSLTSCALE
1
REGENALL
Then the HIDDEN2 VP Linetype now shows up:
But starting in 2025 & 2026 the only way I can see the HIDDEN2 VP linetype override after the above commands is by doing a PLOT PREVIEW:
Paul Li
IT Specialist
@The Office
Message 15 of 16
BillAllenSE
 Thank you, Paul. I guess I'll work in 23 or 24 for now.
I appreciate your help.
Message 16 of 16
paullimapa
You may also want to submit this issue to Autodesk directly by signing into your subscription account….cheers!!!
Paul Li
IT Specialist
@The Office
