Solved by john.vellek. Go to Solution.
Hi @Anonymous and welcome to the Autodesk Community!
It sounds like you might have inadvertently modified your menu somehow.
To reset it, type CUI at the command line. This will open the Customize User interface window. Rt-click on ACAD (menu name) and select Reset Acad.cuix.
Let's see if that fixes the problem for you.
In the ribbon, Draw tab there is a down arrow next to the Draw label, pick that and then pick the divide command.
Be sure to open the point dialog with PTYPE command and pick something other than the first two starting in the upper left and moving right. You can check and change the point type at the command line with PDMODE and then type a number than corresponds to the point type, 35 seems to work for most. See help for PDMODE for the valid number for each one.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
