11:01 AM
Hi guys. Im rather new at modeling and cant get my head arrond this issue I have with loft option.
As you can see on this picture, the width of this is not the same eveywhere - and I want it to be - it should be the width of the right down mark (top 1mm, bottom 2mm). The red objects on the both ends are the same dimensions, so I dont understand why is the part on the curve thicker.
This is a half of the heart Im trying to do, and it is thicker at the bottom (2mm) than it is on the the top (1mm).
Ill attach the dwg file as well.
Any help is appreciated.
Thank you.
