absolute coordinate system
jsworks
Message 1 of 29
jsworks
How do I navigate into the absolute coordinate system?
jksjim
Accepted solutions (4)
Replies (28)
Message 2 of 29
Kent1Cooper
I'm not positive this is what you're asking about, but does turning off Dynamic input [F12 key] do it for you?  If not, can you explain in greater detail?
Kent Cooper, AIA
Message 3 of 29
paullimapa
@jsworks Perhaps you're referring to preceding the coordinate entry with a # symbol which tells AutoCAD to use the absolute coordinate system?
Paul Li
IT Specialist
@The Office
Message 4 of 29
cadffm
summary:
There is no absolute or relative "system", only the possibility of specifying absolute or relative coordinates.
When using the dynamic input ([F1] DYNMODE / [F12]) you can decide whether the input without specification (#@*) should be evaluated dynamically or relatively.
Look at DYNPICOORDS[F1]
If you do not use the dynamic input ([F1] DYNMODE / [F12]), the input without specification (#@*) is evaluated as an absolute coordinate.
Sebastian
Message 5 of 29
jsworks
To Kent1Cooper,
Hi, please read my post to Dimitriy. Other than that, the only other information that I found was that all system variables must be set to "0" so that everything works off 0,0 origin.
jksjim
Message 6 of 29
jsworks
Hello Paul,
Thanks for responding to Absolute Coordinate System. Please read my replies to Dimitriy & Kent1Cooper. If you have a method to set up in Absolute Coordinates, please post.
jksjim
Message 7 of 29
paullimapa
Where's your reply to Dimitriy?
I actually don't see a Dimitriy in this thread.
Paul Li
IT Specialist
@The Office
Message 8 of 29
cadffm
He started another thread in a wrong board
https://forums.autodesk.com/t5/powerinspect-forum/absolute-coordinate-system/td-p/13149367
@jsworks
The only setting you need is
a) Turn synamic input setting off (dynmode <1)
or
b) or with dynmode on, set dynpicoords to absolut (1)
or
c) type prefix #, followed by your x,y(,z) values
[F1]
Sebastian
Message 9 of 29
paullimapa
got it...now it makes more sense when I can see his OP:
@jsworks
Perhaps you can post a screenshot of that page listing the instructions you are to follow to draw your square?
Hopefully it contains more than just use the LINE command.
Paul Li
IT Specialist
@The Office
Message 10 of 29
jsworks
Hi Paul,
To answer your question quickly: NO, IT DOES NOT CONTAIN ANY MORE INFO THAN JUST THE LINE COMMAND. The issue is not the line command; its how to get into the Absolute Coordinate System. A PDF is attached. Note the name of the Template. It sounds like a dwt file name, but I have no such file.
Did you read the post from cadffm? It sounds like good directions, but I'm not able to make any inputs in my AutoCAD 2018.
Jksjim
jsworks@hotmail.com
Message 11 of 29
paullimapa
No PDF is attached.
As for 2018 template files, I cannot say for sure since I don't have that version installed.
But in 2020 you should be able to use File Explorer (File Manager) and open the location where your windows login profile is to see all the templates.
For AutoCAD 2020 and my login profile of PauLpc that is located here:
C:\Users\PauLpc\AppData\Local\Autodesk\AutoCAD 2020\R23.1\enu\Template
Now inside AutoCAD enter command NEW
The Select template window should appear.
Just make sure Files of type is set to show Drawing Template (*.dwt) and you should be able to see that template:
Paul Li
IT Specialist
@The Office
Message 12 of 29
Kent1Cooper
Again, it's hard to tell for sure, but I'm wondering whether by "Absolute Coordinate System" you [or the assignment?] means simply the World Coordinate System.  See Help about the UCS command.
Kent Cooper, AIA
Message 13 of 29
jsworks
Hello Kent1,
Thanks for your reply. I can check "world coord" but for now I'm suspending efforts to find a resolution for absolute coordinates
Message 14 of 29
paullimapa
still waiting for you to attach a copy of the pdf instructions....
Paul Li
IT Specialist
@The Office
Message 15 of 29
jsworks
Hello Paul,
Thanks for attaching the file selection sequence. Unfortunately, it doesn't work. Selecting "acadISO-Named Plot Styles.dwt" continues to open as a DWG file. Refer to the attachments. Not certain why this happens but at this time,
I'm suspending efforts to find a definitive solution for Absolute Coordinates. Thanks for your patience as well as Kent1Cooper & Dimitriy.
Also, you said you didn't receive a PDF of the textbook instructions. That's another mystery; It was clearly attached when I sent it. Anyway, it's no longer of any importance
Thanks again for your patience,
jksjim
jsworks@hotmail.com
Message 16 of 29
jsworks
Hi Kent1,
Forgot to mention in my previous email of suspending finding a resolution for Absolute Coord System, that I wanted to thank you, Paul Li, & Dimitriy for hanging in as long as you all did.
jksjim
jsworks@hotmail.com
Message 17 of 29
jsworks
Hi Paul,
The attachments may have been missing. I'm attaching them in this reply.Opn'g Screen-R2.JPGOpen'g File-R2.JPG
Message 18 of 29
pendean
Community Legend
Community Legend
@jsworks wrote:
... Selecting "acadISO-Named Plot Styles.dwt" continues to open as a DWG file....
When you open a DWT file, AutoCAD automatically gives it a DrawingX name: this is by design, the DWT name will never be present in the tabs.
HTH
Message 19 of 29
Kent1Cooper
@jsworks wrote:
.... Also, you said you didn't receive a PDF of the textbook instructions. That's another mystery; It was clearly attached when I sent it. ....
[If you "sent it" in response to an email notice of a posting, you can't attach things that way.  You must come to the website in a "real" browser.]
Kent Cooper, AIA
Message 20 of 29
paullimapa
So your screenshot shows that you successfully opened the acadISO -Named Plot Styles.dwt as required by the exercise.
This is an empty dwg by design. You can start drawing your LINE command on this drawing. I believe when your text lesson refers to the absolute coordinate system it is the same as the world coordinate system. Since there are no instructions on how you need to draw the LINE then you can just start the command by entering the LINE command and then pick any where on the drawing area for the first point and then anywhere on the drawing area again for the second point. Press the enter key to complete the LINE and you're done.
Paul Li
IT Specialist
@The Office
