AutoCAD Forum
About to Regen - proceed Alert
6 REPLIES 6
RobynFennell
7314 Views, 6 Replies
I am using AutoCAD LT2017 and keep getting a regeneration alert.  How do I make this stop?  I searched answers and found an old one but the command"REGENAUTO" is an invalid command.  This is highly annoying.
6 REPLIES 6
dbroad
in reply to: RobynFennell
Unless they changed something in 2017, regenauto is a valid command. Try typing it again.
Architect, Registered NC, VA, SC, & GA.
RobynFennell
in reply to: dbroad
They must have changed something    😞
Kent1Cooper
I'm not sure REGENAUTO is what you want [and in 2016 (I haven't loaded up my 2017 yet), while it still works, Help already says it's obsolete and "has been removed"].  Look into the EXPERT System Variable if you want to suppress that alert/question.
Kent Cooper, AIA
RobynFennell
in reply to: Kent1Cooper
SWEET!!!  Typed EXPERT, the value was 0, changed it to 1, and it WORKED!!!!  Thank you thank you thank you!!
Kent1Cooper
You're welcome.  It's worth looking it up in Help, because there are a whole series series of levels beyond 1, for how Expert you are and how much you want it to watch over your shoulder and in what areas you want it to leave you alone.
Kent Cooper, AIA
RobynFennell
I will look into it... may solve some of the other minor nuisances.
AutoCAD Inside the Factory
