a scr file can execute a list of same commands only in one scr file.
KOTARAMMOHANR
KOTARAMMOHANR
a scr file can execute a list of same commands only in one scr file. but not different commands in one scr file.
   is it correct
cadffm
this was true for decades, and if you talk about script-command,
but take a look to command scriptcall!
Sebastian
KOTARAMMOHANR
i need one clarity that can we execute two different commands like drawing a line and drawing a cirle both in one scipt file
cadffm
I missunderstood your question, sorry.
A: You can use 100 different commands 1000 times in ONE script, no problem.
But why do you asking? TRY IT first, if further questions: Ask.
From your other thread I know that scripts are still very foreign to you,
start with small things, step by step and you'll quickly get a better idea!
For example, the current color, check your help, variable CECOLOR, controle the current color setting.
type in CECOLOR and press enter
Acad shows the <current> Color and ask for a new Color to set current.
type in your color and press enter.
looks like
Command: CECOLOR
Enter new value for CECOLOR <"BYLAYER">: 50
Command
quick check:
Command: CECOLOR
Enter new value for CECOLOR <"50">:
yearh, it works
Do the same in your Script now, so the script will have 3 lines, the last one is empty:
CECOLOR<press enter for a newline/linebreak>
50<press enter for a newline/linebreak>
save the file as SetCurrentColor50.scr
and start your script by command SCRIPT or Drag&Drop the file into your DrawingEditor.
Circle sample
CIRCLE<enter>
50,50<enter>
10<enter>
And you can write all together in one script to create a circle in color50 at 50,50ucs with r10
(my samples attached, change file extensions from .txt to .scr after download)
Sebastian
