if two versions of AutoCAD show the same problem, you might need to solve some issues with the operating system or the config settings or hardware drivers.
At least a copy of the questions from >>>that thread<<< (which sounds very similar):
Did you already activate your license? Could it be possible that another window is opened and has the focus, but is hidden (outside screen area, behind AutoCAD's application window)?
What does the task manager show? Is AutoCAD active and uses processor power or is AutoCAD at 0% processor/kernel power usage?
What you can try:
- disconnect your workstation from network and try starting AutoCAD again.
- create a new Windows user on your system, admin permission, login with that account, turn off antivirus software and try AutoCAD again.
Questions I have:
- which graphic card and driver do you have
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
