Hi everyone,
I want to ask if is there any way to create a wipe out in the white hatched area as the picture above , instead of a whole rectangle?
I only use white hatch for demonstrated the area need to be wipeout, in my drawing, the hatch area must not be exist!
Thanks for reading and helping me!
Solved by imadHabash. Go to Solution.
Solved by Valentin-WSP. Go to Solution.
@Anonymous ,
Yes. Make sure your view style is on 2D wireframe.
Use the WIPEOUT command (Polyline) and select in this order:
WIPEOUTFRMAE = 0 (to turn frame off)
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Click on below image to see how it will be done . draw a polyline first as shown , then convert it to a wipeout .
