A beginner and want to learn more about AutoCAD
What is the best AutoCAD product for us beginners?
Any suggestions?
a00812364
Hello James,
I'm assuming you mean "AutoDesk" (the company) program.
For Architecture, AutoCAD is the simplest to start off with. It'll give you a good introduction to AD's other programs, and is relatively good for accurate 2D drawings. Many contractors in our region use it for plans and simple elevations.
For larger projects of more complexity, I'd highly recommend Revit. Revit is easy to get in to, harder to master, but will overall save you time in every situation. Often the products are bought together.
If you're looking for tutorials or training instead, Youtube is a great place to start. You can also try online course websites (ex. Lynda.com) for a more structured instruction.
Yours truly,
MC
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Let us know in which branch you'd like/need to work. It makes a difference if you are working with architecture, mechanical engineering (e.g. automobile), infrastructure, some artistic design etc...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Emmsleys
Hello @Anonymous
Welcome to the Autodesk Community!
Any suggestions?
I think it heavily depends on what type of work you are doing. Would you be able to share a little more?
Thanks, Happy Posting
Sarah Emmsley
Technical Support Specialist
Thank you for your reasonable answer a00812364.
I'd like to venture my skills in the architectural industry. Your answer really helps!
Alfred.NESWADBA
Well, in that case take a look to AutoCAD Architecture >>>click<<< (fully based on AutoCAD) or Autodesk Revit >>>click<<<.
They both are more specific to architectural design.
- alfred -
Alfred NESWADBA
