4K monitor - display issues
Message 1 of 16
Will someday autocad support correctly 4k screens???
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
Eventually: when? no one here is ever going to tell you.
For now AutoCAD is not designed for high-res monitors. AutoCAD through version 2017 only runs on displays set to 1920x1080 (also try 2560x1440 and up to 2560x1600 if you have that option) and at 100% text scaling (no more than 125% text scaling). It will not look good on 4k displays settings on modern PCs and laptops 😞
Read all about it here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gra...
Message 3 of 16
Ok, I got it. However, in a near future does Autocad will sopport properly 4k monitors?
Message 4 of 16
pendean
Community Legend
Community Legend
Those that know cannot say, everyone else is just guessing. Flip a coin.
Message 5 of 16
rkmcswain
What he means is that Autodesk is a publicly traded corporation and they do not discuss future plans.
Message 6 of 16
RobDraw
If the use of 4K displays becomes more widespread, why wouldn't they? It would be silly not to.
Rob
Message 7 of 16
pendean
Community Legend
Community Legend
It's likely to happen, but no one knows when. Sit tight and wait like all the rest of us.
Message 8 of 16
rkmcswain
Or if you don't want to wait, switch to a competitive application that does support the features you want/need.
Message 9 of 16
pendean
Community Legend
Community Legend
AutoCAD fo MAC, in MacOS, supports Apple's 5k displays. No software to buy, just log into the subscription portal an get the MAC version.
Message 10 of 16
ScottHodges
I did read in a similar post that an AutoCAD update was released today that should address this issue, but am awaiting user confirmation that it works
Message 11 of 16
Where did you read it?
Message 12 of 16
rkmcswain
It does not specifically say anything about 4k, but read it for yourself and give it a try.
Message 13 of 16
john.vellek
Hi @ScottHodges,
I have it running on a couple machines and it seems to work well!
I hope that you find this to be the case as well.
John Vellek
Message 14 of 16
mchristop
I have been somewhat successful with this work around with Autocad Architecture 2017 and every other application that has display issues.
http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
The Autocad Start screen doesn't work properly, but I just click the + tab to start a new drawing.  Then Everything seems groovy.
Message 15 of 16
pendean
Community Legend
Community Legend
The workaround fails in WIn10Pro...
Message 16 of 16
mchristop
All of our computers are Windows 10 Pro. It should work.
I add the setting to the Registry.
I add the manifest file to the exe location.
It worked on (3) Intel Nuc computers and one Dell XPS15 all running Win10Pro.
This was before the 2017.1 update was available.  I will continue to test when I get some time.
